Can i connect two CANinterface with single CANport PCI-8513
Hi everybody,
I have a 1 port PCI-8513 CAN card and have two CAN interfaces with two different baudrates.
Can i connect the two CAN interface with different baudrates to PCI 8513 at same instance of time?
Is PCI-8513 support two different CAN interface with different baudrates if i connect at same instance of time?
(6,306 Views)
If you connect to disparate CAN networks together that are running at different rates, you will generate bus errors, regardless of whether the 8513 is connected or not.
(6,298 Views)
