Can you increase the limit on number of NI-CAN messages?
There is a limit to the number of CAN objects that can be set up using the NI-CAN driver call ncConfigCANObj.
Is it possible to increase or otherwise work around this limit?
Below is the error message encountered when breaking the limit:
Error -1074388736 occurred at NI-CAN Configure
CAN Object
(ncConfigCANObj.vi)
Possible reason(s):
NI-CAN:  (Hex 0xBFF62100) Exceeded limit for total number of messages. Solution: For Channel API, decrease the
number of messages; For Frame API, decrease number of CAN Objects that receive data by using the Network
Interface to receive frames.
Any suggestions welcome.
Olof
(6,531 Views)
Hello Olof,
Unfortunetely, there is now way to get around this limit.  Some of the reasons for this is that determinism starts becoming a problem if the number of objects increases.  You can see more information about this in this knowledgebase.
I would sugget to post your code and we can try to help you find ways of simplifying it and using less objects/messages.
Have a great week.
O. Proulx
www.ni.com/support
(6,489 Views)
