CanErrComm
HI,
I wanna know if the controller is BusOff state, NI-CAN returns CanErrComm, ok, but where can i get it ? (return of ncWrite() or where !)
thenk you
(5,039 Views)
The next NI CAN function you try to call after you have the bus off will give you the error message. You can poll for any state using the get attribute function.
DirkW
(5,028 Views)
Hi DirkW
Sorry but i am new in that field, What do u mean by "Get Attribute Function" ??
another question : if i send a message (from my application under CVI ) to  the  calculator, und the calculator is out of order, How can i check that ? how can i know that my frame doesn't reached the calculator ?
thank you Dirkw
(5,026 Views)
Hi
See page 11-61 of the CAN manual comming with the driver, for how to use the state property with the get property function with CVI.
Attached you can find an example, that writes and reads data, thus you can see how to create a good error handling, to get an error if your device is not acknowledging your request.
DirkW
(5,015 Views)
HI again,
I am tring to used the exmple, juste before that : i have a NI-CAN 2.1.3  und S1 board, i hope that don't make a trouble,
what about the buffer (write queue und read queue) , if i try to use ncWrite und ncRead in the same function (they have the same CAN Network Interface Obeject), will that make a trouble?
for exemple :
ncWrite(Tx,.....);
ncRead(Tx ....);
thank you again
(5,011 Views)
The example should work with series 1 and your driver and yes you can use the same port handle for both write and read.
DirkW
(4,983 Views)
thank u ,
(4,980 Views)
