CanWarnComm, what is it ?
When i power my external device OFF and then back ON i sometimes get the status warning "CanWarnComm" (0x4000000B) from the NI-CAN card, when i am writing to the device.
I am wondering how severe is this warning and how is it typically generated ?
Thanks for your time...
(3,998 Views)
The "CanWarnComm" status warning indicates that CAN bus problems have been detected, but communication is proceeding. This warning corresponds to the CAN controller chip on the NI-CAN card entering what is known as "CAN Error Passive state". This can happen for a number of reasons, but from what you are describing, it sounds like when you power your external device OFF, there is no longer a second CAN device on the network to acknowledge (or "ACK")messages. Remember that a CAN message must be ACK'd by another device on the bus, or the transmitter will attempt to re-transmit. After a number of re-transmissions, the device enters the "Error Passive" state as a mechanism to confine errors.
So, the warning you are seeing is expected behavior when the NI-CAN card i
s left as the only active device on the bus.
(3,998 Views)
