Check connection
Does USB CAN provide the CAN check procedure? Say during frames transmit and receive, I wish to interrupt the connection and check if the connection is still alive.
(4,317 Views)
Hello Slytherin:
USB CAN does not provide that feature. However, you can use the bus monitor utility to monitor the messages.
Roland A.
Check out VI Roadshow
(4,303 Views)
