Configuring Signal Values in NI-XNET database
I'm trying to set up my data base signals so I can set signal values. Specifically, I want to set different values for a specific byte in the data field of the CAN signal. See attached screenshot. I'd like to set byte 2 to different values within the range of 0 to 255. Does any one know how I'd go about doing this?
(6,167 Views)
We are now working together on this with a Service Request, but for completeness of the forums, you have set up the database correctly and you now use the XNET API to write the signals.  There are examples in the example finder in Hardware Input and Output>>CAN>>NI-XNET>>Intro to Sessions>>Signal Sessions.
Cheers,
Chris
(6,159 Views)
