Configuring XNAT CAN interface for UDS communications
Hello. I am learning how to use ADCS for UDS communications.
For hardware I have NI XNET CAN PXI-8313.
All examples for ADCS show how to set up communications, open diagnostics, read and write. But, they do not show if I still need to configure CAN interface, such as termination.
Examples for XNET show how to set up termination.
I am assuming I have to create XNET section in parallel for the same CAN interface so I can set up termination. I did not see termination in properties for diagnostics session.
(5,048 Views)
You can create a stream session in parallel with ADCS to set the termination like so:
Jeff L
(5,044 Views)
Accepted by topic author Rus_K
ADCS also has a dedicated property that can be used to set the termination if you do not need to set any other interface properties.
Page 5-19
Jeff L
(5,042 Views)
Thank you.  I missed this settings.
(5,035 Views)
