Convert Channel to Frame
I don't imagine there is, but is there any way to convert CAN Channel API data into Frame API data?  Or any way to use a CAN database file with the Frame API?
I've got access to a database that was created in the Vector CANoe program and I would like to use it in LabView.  The problem is that I only have the USB-8473 CAN adapter, and that cannot be used with the Channel API.  Is there any way around this, or do I have to purchase a different CAN adapter?
Thanks.
(5,019 Views)
You will get the best performance for your channels if you use a PCMCIA device with the NI CAN Channel api, but you could use your 847x USB device with the virtual Interface workaround as described with the following KB:
http://forums.ni.com/ni/board/message?board.id=30&message.id=2700
DirkW
(4,998 Views)
Hey guys,
I just wanted to post the link that I think Dirk intended on posting.
How to use the NI-CAN Channel API with USB-CAN Hardware?
Nick D.
(4,993 Views)
