DAQ CAN "analog trigger"
Dear all,
 I know it's possible to synchronize DAQ and CAN, also with frame API.
I need to synchronize a DAQ device (PXI 6070E) with a CAN device (PXI 8461) using frame API. The synchronized acquisition has to start with an analog trigger (ai1 for example on PXI 6070E).
In order to do that I began with CAN Frame API Input DAQmx Input.vi (from Find Example) and I added analog trigger functionality to DAQmx task (see attached file).
This solution seems to work well with sample rate <  1000S/s.
When I try with higher sample rate 20kS/s, for example, VI start correctly, but it stops and popup an error.
NOTE: The original VI (CAN Frame API Input DAQmx Input.vi) hasn't this problem. I tested it in range (0 - 50)kS/s.
Some ideas?
Thanks in advance.
Paolo.
(6,394 Views)
Hi Paolo,
I had a look at your vi.
Why do you need another while loop with a DAQ Assistant in parellel with the DAQ and CAN acquisitions?
Which error code and message do you get?
Serena M.
(6,379 Views)
Problem solved! My CAN Card was out of order.
p.
(6,353 Views)
