Detect DNET card
What is the best way to detect all the NI DNET cards installed in your computer? Currently, I try to open each interface (
to see if it is available (I use ncOpenDnetIntf() and iterate through "DNET0"...."DNET63" and see if that call is successful).
There must be a better way? Iterating through all the IDs are very time consuming..
Message 1 of 8
(6,232 Views)
Hi Haugan,
NI-DNET does not give you the tools but you can use the ncGetHardwareInfo() from NI-CAN for a more elegant way to solve this. In pseudo code:
ncGetHardwareInfo(1, 1, NC_ATTR_NUM_CARDS, 4, &number_of_cards)
FOR card=0 TO number_of_cards {
    // make sure, it’s a Series 1 CAN card,
    // as NI-DNET does not work with Series 2 NI CAN hardware
    ncGetHardwareInfo(card, 1, NC_ATTR_HW_SERIES, 4, &series)
    IF (series == NC_HW_SERIES_1) {
        // make sure, it’s a high-speed CAN card,
        // as NI-DNET does not work with low-speed CAN hardware
        ncGetHardwareInfo(card, 1, NC_ATTR_TRANSCEIVER_TYPE, &type)
        IF (type == 0) {
            ncGetHardwareInfo(card, 1, NC_ATTR_INTERFACE_NUM, &interface)
            PRINT ("DNET%d, ", interface)
If you only have 'real' NI-DNET hardware (1-port, series 1, high-speed NI CAN cards), you don't need the blue portion of the code.
-B2k
Message 2 of 8
(6,218 Views)
You mean "FOR card=1 TO number_of_cards {"?
I tried iterating from 0 but that gave me a status error saying that one of the arguments to the ncGetHardwareInfo()function call was wrong.
Also, I get an unknown (0xFF) tranceiver type when I query for NC_ATTR_TRANSCEIVER_TYPE.
Message 3 of 8
(6,203 Views)
What driver versions are you working with?  NI-CAN?  NI-DNET?  Have you tried upgrading to a newer revision?  Does the function mentioned above always return FF, or is just with Series 1 cards?
Logan S.
Message 4 of 8
(6,181 Views)
I haven't tried it with other cards than the one I have. However, the card says that it supports both high-speed and low-speed CAN.
I am using the latest NI-DNET drivers (1.4.2).
Message 5 of 8
(6,184 Views)
Hi Haugan,
From your description (the card says that it supports both high-speed and low-speed CAN), I assume that you have a PCMCIA card. ncGetHardwareInfo(NC_ATTR_TRANSCEIVER_TYPE) is not supported on the PCMCIA form factor, which explains your return value of 0xFF.
Further more, all NI-CAN/NI-DNET function calls return a status, so all calls should be execute like this:
status = ncGetHardwareInfo(card, 1, NC_ATTR_TRANSCEIVER_TYPE, &type)
IF (status <> 0)
  PRINT ("ncGetHardwareInfo returned error code %d", status)
That way, you know if the function even executed successfully. Here's the modified code (however, it doesn't check the status to make it more readable).
status = ncGetHardwareInfo(1, 1, NC_ATTR_NUM_CARDS, 4, &number_of_cards)
    status = ncGetHardwareInfo(card, 1, NC_ATTR_HW_SERIES, 4, &series)
        // check, if it's a PCMCIA card, as we can't
        // query the transceiver type for this form factor
        status = ncGetHardwareInfo(card, 1, NC_ATTR_HW_FORMFACTOR, 4, &formfactor)
        IF (formfactor <> NC_HW_FORMFACTOR_PCMCIA) {
           IF (type == 0) {
               status = ncGetHardwareInfo(card, 1, NC_ATTR_INTERFACE_NUM, &interface)
Again, if you only have 'real' NI-DNET hardware (1-port, series 1, high-speed NI CAN cards), you don't need the blue portion of the code.
-B2k
Message 6 of 8
(6,163 Views)
Attached is a VB example that I wrote that might help.  It's not perfect, but give it a shot, if you are in VB.
Logan S.
Message 7 of 8
(6,158 Views)
Thanks!
Your example was very helpful.
Message 8 of 8
(6,090 Views)
