Differ for MAX CAN databases?
I've got many Vector CAN databases that I need to merge together into a central database.  Unfortunately, Vector requires an admin license to be able to perform a difference function on the databases to determine what is common and uncommon among the databases.  I was thinking about importing them all into MAX and seeing if there is a difference feature in MAX which I could use to merge all the databases together into one.  Does anyone know if this is possible?
thanks.
(3,710 Views)
Hi buff,
 the NI CAN database editor has a kind of a difference feature. If you import different DBC Files to the MAX database, it shows you duplicated channels and messages with a note of exclamation, but you have to fix this duplicated issues by your own.
And you can not save your new database to a Vector DBC file, because the NI CAN driver can only save to NIs NCD format.
DirkW
(3,700 Views)
