Differentiate standard Id and Extended ID
I was wondering if there is any way to build a simple program,  where an Arbitration Id is given as a input to a logic, which will return the output as 0 or 1. Say 0 means standard Id and 1- means Extended Id. If any one know how to do this, can you please share the information.
Thanks in advance,
Sulekha.
(6,452 Views)
Hi Sulekha,
You can write a simple application yourself that will do this. The structure of the CAN frame can be identified here. You can parse the frame in a SubVI, convert the Hex Frame to Binary and check the binary Extender bit to see if the ID is extended or standard.
Raj
(6,440 Views)
