Does Anybody know the Errorcode 196619 in relation to standard 2 port NI CAN Controller, LabVIEW 6i and WIN NT 4 - SrvPck 6.
Frequently the WIN NT 4 System hangs up when I start a LabVIEW Can Application. ( i.e. the NI CAN Examples.)
If I'm able to start the application it works propperly. I'm using the two ports of the PXI CAN Controller to test the communikation. ( CAN0, CAN1 )
(4,263 Views)
Be sure that the card is plugged in tight. Do any other PXI cards work in the chassis? If not, there may be something wrong with the PXI hardware.
Also, be sure to install the latest CAN drivers from ni.com.
Randy Solomonson
(4,263 Views)
