Does anyone using CANcaseXL experience?
As this topic, I had a CANcaseXL of Vector ,But I don't know how to use vxlapi.dll to monitor CAN.
It's very hard to setting ,, Does anyone can share some experience how to RECEIVE CAN to us?
I will appreciate to you so much.Cat Very Happy
Message 1 of 19
(9,622 Views)
Message 2 of 19
(9,611 Views)
Using these drivers I've had decent success. Vector sells a LabVIEW driver but it sucks.
https://decibel.ni.com/content/docs/DOC-30180
Message 3 of 19
(9,596 Views)
Munna232 已寫:
Check this....
http://forums.ni.com/t5/LabVIEW/LabVIEW-vxlapi-CANCASEXL-configuration/m-p/1666114/highlight/true#M5...
Hey , Thanks Munna ,,
I had download your linking file ,, But I found this CAN sent part,, I don't know where is RECEIVE part...
Can you give me some guide?
Message 4 of 19
(9,587 Views)
Have a look at the document  attached a link to.
It has everything you need.
Troy - CLD "If a hammer is the only tool you have, everything starts to look like a nail." ~ Maslow/Kaplan - Law of the instrument
Message 5 of 19
(9,584 Views)
Hooovahh 已寫:
Hi , Hooovahh
Thanks for you shared this link , I try to research it , But I am not found where is CAN RECEIVE part.
There are just CAN transmit and LIN received part...
I try to used these driver , but still can not working..
Can you share step of function name to us?Cat Very Happy
Message 6 of 19
(9,583 Views)
TroyK 已寫:
Hi ,Super man
I used this link and downloaded file I just found there have LIN mode
Can you give me some guide to change to CAN received mode?
Message 7 of 19
(9,582 Views)
Accepted by topic author HOYO
It is better that you look at the vxlapi.dll documentation and understand what is going on, but I added a CAN receive example to the community document anyway.
CAN Receive Example.vi added due to popular demand.
Message 8 of 19
(9,580 Views)
Hey HOYO,
I think you have not seen that link completely.
I have added Receive part example with help of "TroyK".
http://forums.ni.com/t5/LabVIEW/LabVIEW-vxlapi-CANCASEXL-configuration/td-p/1666114/highlight/true/p...
Anyway, Troy posted updated code. Please use that.
Munna
Message 9 of 19
(9,561 Views)
TroyK 已寫:
I have to thanks for TroyK,, My device of CAN can worked normally.
I know it's very hard to setup some funtion and parameter,,Your vi is very useful!
You are my supermanCat Very Happy
Message 10 of 19
(9,522 Views)
