I would consider myself fairly experienced with the ECU Measurement and Calibration Toolkit, but even i'm stumped on this one.
I'm trying to do some simple data acquisition using the Channel API via a polling technique and I get the following error.
Error - 301025 occured at MC Read NChan 1Samp 1D Dbl.vi: The byte ordering for this item is invalid. Most likely it has not been initialized correctly.
I'm fully aware of what this error is saying (I think), but I have no idea how to fix it. I've tried changing the byte order using the Set Property VI, but it doesn't help. The byte order for the device i'm attempting to communicate with uses Motorola byte ordering.
Changing the byte ordering using the Set Property VI doesn't seem to do anything.
