ECU Measurement & Calibration Toolkit with CompactRIO
Hi, I need to develop an application to make by-pass in some functions of a diesel engine ECU. I have a CompactRIO and a 9853 module. With the CAN VI's I'm able to read the CAN messages from ECU, but I want to know if it's possible to use the ECU Measurement & Calibration Toolkit with CompactRIO in Real Time.
I was searching on Example Finder and found the examples to use the toolkit on host computers to using A2L files to access the ECU's variables. But I didn't found a way to use it on cRIO-RT.
Any help will be apreciated.
(6,479 Views)
Hello Letreca,
I apologize for the delay in answering, but unfortunetely, we do not officially support the cRIO module with the ECU  Measurement & Calibration Toolkit, but you can see this example that shows how you can use it.
Let me know if it helps.  Have a great day.
O. Proulx
www.ni.com/support
(6,397 Views)
