Echo Frames Transmission Guaranteed?
Recently I re-architected some XNET code to use Frame In/Out Streams (this was essential to run XCP at the same time - however XCP was inactive in this test).
However, I quickly ran into problems. It appears that the required frames were not being transmitted - verified using a PCAN adapter and CANAnalyser. I was able to read received frames. The transmitted frames were configured with echo enabled and I was seeing them in the receive buffer.
Rolling back to a previous version fixed the problem so a hardware fault seems unlikely.
My question then remains: is it possible to see echo frames in the RX buffer but not actually transmit the frames?
Admittedly I need to do some better error checking but I don't have access to the rig at the moment...
Many Thanks
Nick
Message 1 of 1
(2,525 Views)
