Error 0xbff62002 (CanErrDriver); An internal error occurred in the NI-CAN driver
We also have the problem that we get the Error -1074388990 (Hex 0xBFF62002). We use a PXI-System and a DeviceNet Card (PXI-8461), LabVIEW 8.5, NI-DNET 1.6.1 and NI-CAN 2.5.2.
The problem occurs in the first VI trying to establish a connection to the CAN Device. We tried all the recommended things like installing the newest NI-CAN version (both on the Windows computer and the PXI-System) or changing the slot of the PXI-Card.
Has anybody a solution?
Thanks for help, dave
Message 11 of 12
(1,733 Views)
This is not the way you should work on this forum. You posted the same problem to four different threads. Don't do that. Instead you should open your own thread and deliver as much information as possible.
The 0xBFF62002 error is internal and there is not that much you can do. Whenever this error occures a nicanerr.txt file is generated to the following location:
\\Program Files\National Instruments\NI-CAN\bin
Attache this file to your own thread and if possible add ashort example showing this error, so we can reproduce it here.
If you work that way, i am pretty sure we can help.
DirkW
Message 12 of 12
(1,720 Views)
