Error 1074388710
Hai
     I am getting this error message "Error 1074388710" after sometimes when i run my program
how to solve this, I attached my Vi.
thanks
sk
I am using LabVIEW 7.1
(3,739 Views)
The error you got means that some times you read not fast enough,thus an overflow occures on driver level and data loss is the result.
This is caused perhaps by your case structure , which can prevent the Read to be executed. You should always read inside the while loop, so perhaps you can put the write in their own Case structure and remove the case from the read to read at every iteration.
DirkW
(3,733 Views)
