Error -1074388984 occurred at CAN Write (Multi-Chan Single-Samp 1D Dbl).vi
I keep running into an error with CAN Write.  The error keeps telling me that I have to many messages in the CAN Write que and need to clear then or that the messages might be to short or that I may have to wait until there is a successful read.  I believe the memory is full....Any suggestions
Message 1 of 11
(8,949 Views)
This is also more on the error:
Possible reason(s):
NI-CAN:  (Hex 0xBFF62008) Write queue overflow.  Solutions for CAN Object: Increase the length of the write queue; Wait for Write Success state prior to calling Write; To transmit recent data only, set the write queue length to zero. Solutions for Net Interface: Wait for Write Mult state then repeat Write; Get Number of Entries Free attribute and Write that number of frames.
Message 2 of 11
(8,948 Views)
Hey Clarence!
How are you doing?  Usually, when this error occurs, it is because there are no CAN devices acknowledging the data sent on the bus.  The write buffers would get full and get sent over and over again.  Please post your NI spy logs.  A procedure on how is linked below.
http://digital.ni.com/public.nsf/allkb/8D890EC09B15C05A86256E6F007E3E86?OpenDocument
Also, did you try running some simple commands over the example VI?  Thank you!
Best Regards,
Song Mu
National Instruments San Diego
Message 3 of 11
(8,933 Views)
1.  nctInitialize ("Fuel Value,Pump duration angle,Pump a...", 0, 3, 0, 1)
Process ID: 0x00000578         Thread ID: 0x000001BC
Start Time: 15:38:26.656       Call Duration 00:00:00.015
Status: 0 (VI_SUCCESS)
2.  nctStart (1)
Start Time: 15:38:26.671       Call Duration 00:00:00.000
> 3.  nctWrite (1, 1, NULL)
> Status: 0xBFF62207
4.  nctClear (1)
Start Time: 15:38:26.671       Call Duration 00:00:00.063
Message 4 of 11
(8,913 Views)
Im still having the same problem. I am working on going through the examples.  Thanks for your help and hopefully we can come up with a solution...
Message 5 of 11
(8,912 Views)
No, its not the same problem. Now you have the 62207 error, which means that you have not specified all required inputs.
DirkW
Message 6 of 11
(8,900 Views)
Hey Clarence!
DirkW is right, it seems like this is a different error than you originally posted.  Could you try to run the simple GPIB communication example VIs to run simple commands?  If we can get that to work, then we can work on getting the application to work.
Best Regards,
Song Mu
Message 7 of 11
(8,896 Views)
Okay.  With these examples do you need some type of VISA drivers to be installed on your computer.  When I look for the example on the LABVIEW Help page there are a lot of different choices.  I chose the LABVIEW GPIB.vi example to use.  Is this the correct example and how do i use it?
Message 8 of 11
(8,824 Views)
If i use the basic serial read and write example, I recieve this error:
Error -1073807202 occurred at Property Node (arg 1) in VISA Configure Serial Port (Instr).vi->Basic Serial Write and Read.vi
Possible reason(s):
LabVIEW:  (Hex 0xBFFF009E) VISA or a code library required by VISA could not be located or loaded.  This is usually due to a required driver not being installed on the system.
Message 9 of 11
(8,823 Views)
What is GPIB?
Message 10 of 11
(8,822 Views)
