Error-1074388991 message
Hai
i am sending a CAN message to my ECU so the ECU will send 4 consecutive frame at 4ms time interval.
so in my program i wait for 2 seconds and read the frames but the ncwait function send error message
Error -1074388991 occurred at NI-CAN Wait For State
(ncWait.vi)
Possible reason(s):
NI-CAN:  (Hex 0xBFF62001) The timeout of a wait or notification function expired before any desired state occurred.  Solutions: Increase value of Timeout parameter; Verify your cable connections and operation of remote devices.
how to solve this problem
thanks
sk
(4,548 Views)
hi
please attach your code so i can see what goes wrong.
DirkW
(4,539 Views)
Hai
i attached my VI,
i need all the ECU responce to be seen in the output window, so that i can scroll the data received from ECU
thanks
sk
I am using LabVIEW 7.1 / NI PCMCIA CAN
(4,532 Views)
I can not see any wait function within your code. See the attached example for more info on how to use a wait with NI CAN.
DirkW
(4,528 Views)
