Error 8706
I'm getting an error (-8706) from my program. I'm using a slighty modified VxWórksBasicInputOutputDMA example, and I get the error after "Add Selected Channels from File.vi", right in the beginning. Why is this?
I'm using LV 8.6, cRIO-9012 with Can module 9853. I'm sending the data from CanCaseXL.
Tim Jansson
(11,920 Views)
Hi Tim
Have you read this KB?
Best Regards
David
NISW
(11,899 Views)
Hi!
Yes, I have! And the drivers are installed.
TJ
(11,896 Views)
Hi Tim
I've haven't really found much on that error code. Are you getting anything more, like an indication where it's going wrong or a description? Would it be possible to have a look at your code as well?
Best Regards
David
(11,880 Views)
Hello David!
Sorry for the delay, but I've been working a lot on a CAN-USB project.
I attached a picture of where the problem is generated. I really have no clue why this problem exists.
Tim
(11,789 Views)
Do you get any error description?
(11,725 Views)
Can you move your .ncd file to cRIO memory(If its not there already) and check if the error repeats ?
(11,719 Views)
