Error Code 301031------MC Characteristic Write.vi------M&C Toolkit
I can read a characteristic with MC characteristic Read.vi.
But it's wrong when I write a value of a Characteristic with MC Charateristic Write and the error code is -301031.
What is the meaning of this error code and How can I solve the problem?
By the way, Where can I search the information about error codes of  the M&C toolkit?
(6,445 Views)
The explanation of the error code -301031 is:
Error -301031 occurred at an unidentified location
Possible reason(s):
ECU Measurement and Calibration Toolkit: (Hex 0xFFFB6819) The measurement or characteristic is read only.
You can use the LabVIEW "Explain Error" window to get detailed information about the error codes.
(6,332 Views)
