Error Frame logging using NI-XNET hardware
Hi all, I am using NI-XNET hardware (PXI-8513 board) to send diagnostic messages to electronic control unit devices.
I am logging transmitted and received CAN messages. Now I would also to log error frames messages.
How can I perform this?
Claudio
(7,610 Views)
just set the interface property
Interface:Bus Error Frames to Input Stream? = TRUE
The Bus Error Frames to Input Stream? property configures the hardware to place a CAN or
LIN bus error frame into the Stream Input queue after it is generated. A bus error frame is
generated when the hardware detects a bus error. For more information about the bus error
frame, refer to Special Frames in the NI-XNET Hardware and Software Manual
btw this feature was introduced in NI-XNET 1.7
(7,608 Views)
