Error in NI-CAN Configure Network Interface Object
Hi, I have started receantly to learn LabVIEW and NI-CAN. Im using version 8.2.
I have read the NI-CAN Manual, and look at the examples.  I have tried sending can Frames with LabView and checking them with CAN Analyzer on another computer.
I use the following configuration
ncConfigCANNet -> ncOpen -> ncWriteNet -> ncClose, my problem is that sometimes these configuration works and some times it doesnt, For example I run it and it works, then I stop it change one of the configuration settings of the config.vi, and when I run the application again I get Error (Hex 0xBFF62007)  for the ncConfigCANNet which states that I tried to make changes in the configuration while the object  was still running. But I made the changes after stoping the application, so I dont know why I get this error.
can someone please tell me what am I doing wrong?
thanks a lot
(5,805 Views)
well the error only appears if the port is allready open and you try to set attributes. If you could post your code, i could have a look to it.
be sure to open the port only ones and if you need to use the set attribute function , open the handle with nc config start on open = false and start the communication after setting all attributes using the nc action start function.
DirkW
(5,800 Views)
Hi, Here is the VI I have created it is a very simple one, but I dont know why I get the error in the ncconfigCANNet funktion.
I also recorded the process with NI-Spy
This is what I did:
1. Run the VI -> It does RUN
2. Change the Write and Read queu to "0"; RUN The VI -> Doesnt RUN - ncCOnfigCANNet Error
3. Change the Write and Read queu back to defaukts "10"; Run the VI-> It works again
If you could have a look at them it would be great, thanks a lot
(5,796 Views)
This is what I did:
(5,784 Views)
Had a look to your VI and implemented a wait to wait until the message is written to the bus , otherwise it could happen that the close is killing the handle before the message left.
But i could not reproduce the error you got. Perhaps you should install the newest CAN driver as well.
DirkW
(5,774 Views)
