File handeling in CAPL
Hello All,
i want to know how to copy the data of received frame to txt file using CAPL script.
ex:If received data is 05 6E 01 02 03 01
Then i want this data to be copied to output.txt file with farmate shown below
[output]
data = 05 6E 01 02 03 01
Jagadeesh Burle
(4,811 Views)
This question (and the other one you posted here) would probably be more appropriate on a CAPL discussion forum.  NI and LabVIEW have nothing to do with CAPL and you will likely not find much support for it here.
(4,790 Views)
