Flexray Frame Open issues
Maybe I should add, that you may close the particular database objects, but not the entire database. This indeed would revert the settings you did before starting the session.
Message 11 of 14
(4,021 Views)
What I found is if I modify the frame properties, create sessions, and then close all database objects as well as the database before I start the sessions it doesn't seem to give me the errors I have been recieving, and the frames seems to still stick with the changes.  I also tried to close all objects except the database itself until after I stop and clear the sessions.  The I close the database.  Then I still get this error which I will attach.
Message 12 of 14
(4,011 Views)
can you post the NI-SPY log file, maybe this helps us to see where your problem is coming from
Message 13 of 14
(4,003 Views)
NI-SPY log is a good suggestion. Stop the execution immediatly when the error occurs (on the error output of the Database property node use Custom Probe / Conditional Error Probe and in the Condition tab set the checkbox on Error). Also set a probe on the IO name input of the XNET Database property node (or Open Database database output).
When the VI stops on error, save the NI-SPY logfile and post it together with the database IO name.
Message 14 of 14
(3,996 Views)
