For the CAN instrument is the 120 ohm Resitor to be added by the customer
I am testing several CAN devices. The CAN communications has various resistance values.
R= 120 ohm
or 2600 ohm.
3300 ohms
The PXI-8464 CAN instrument will not read any frames until I installed a 120ohm resistor.
 I add a resistor to the 2600 ohms to reduce the circuit resistance to 120 ohms.
Then the resitance between CAN HI and CAN LO is 60 ohms.
Will this damage the PXI-8464?
(4,193 Views)
According to the ISO 11898 specification, for High-Speed CAN, you must use a cable with a nominal impedance of 120R and it must be terminated with a 120R resistor on both ends. So 60R, is not only supported by the interface but this is the expected load on the bus.
Some links :
NI-CAN User manual  --> Cable Termination, page 4-5
http://digital.ni.com/public.nsf/allkb/B5D65DF99543205486256FA500670B09
http://digital.ni.com/public.nsf/allkb/E64E8655D2B41DBA86256A530055E6BA
(4,178 Views)
