Frame Channel Conversion Library: Write
In LabView I use "Add selected channels from file" and use my .dbc
In a CAN message I have more than one channel.
I now want to write to the first channel in the message. This does not work.
The "Convert Channel to Frame" always creates a data frame that fits the last channel in the message. Well, there is no way to wire "Channel" to the vi.
Is this correct and is there a workaround?
(7,020 Views)
could you provide a database file containing this message and all the channels for that message?
DirkW
(6,988 Views)
I've worked it out.
The key was to not just send a single value but an array of data fitting the channel/message order.
Thx anyway.
(6,983 Views)
one single frame has 0-8 byte of data (Data byte). In Data byte field we logically allocate more channels.
Using frame API is it possible to write one single channel? I don't want to write all data field only a single channel.
Thanks!
Paolo.
(6,795 Views)
