Frame Channel Conversion Library for LabwindowsCVI
Could someone help me to identify Frame Channel Conversion Library for LabwindowsCVI. I found a library for labview and it is working fine with my USB8473. But i really need to get it working with Labwindows. Have anyone tried to access the frchconvlib.dll from labwindows? Thanks in advance.
(6,712 Views)
Unfortunately, the C API is not documented, nor is it stated as a supported interface.
With that said, you may be able to dig into the VI's of the Frame Channel Conversion Library and pull the function prototypes from the Call Library Function Node on the block diagram of each one. With this information, you could call the functions from the dll (usually located here: C:\Program Files\National Instruments\NI-CAN\CAN Frame Channel Conversion Library 1.0.2\Drivers) from within C.
Let me know your thoughts and if you have any success.
Peter Flores
(6,702 Views)
Sure. I will give it a try and let you know.
(6,697 Views)
