Frame to Channel Conversion
We have this VI that sends a message to active a sensor and the starts reading raw data. We understand this data is CAN frames which now we need to convert to channel in order to get scaled values. We tried "CAN Frame to Channel vs 2_2_2" from NI but it needs som cRIO parameters that we don't have. We also looked at the "CANConversionLibrary" but nothing that applies to our case.
How could we process the "Data" shown in the last column of the attached VI?
Thanks!
(6,413 Views)
This is nothing you typically solve by using a channel database file. The sensor manufacturer normaly explains how to translate the raw values to physical values within the manual for the sensor. You should call the manufacturer or search their webpage for a manual.
DirkW
(6,387 Views)
