Has anybody captured an error frame occurence with CAN driver version 2.2
Hi All,
We finished and released the new NI CAN 2.4 driver version, which is addressing the error frame logging feature. The driver brings examples for LabVIEW and CVI to explain how to enable the error frame logging feature.
Specifies whether to log bus errors when the interface detects a bus error. For CAN interfaces, the bus error frame is logged when a bus error is detected. The Log Bus Error? attribute is not supported by Series 1 CAN interfaces. This attribute has to be set prior to starting the Network Interface.
You can download the driver from our ftp server only:
ftp://ftp.ni.com/support/ind_comm/CAN/2.4/
DirkW
Message 11 of 16
(3,056 Views)
Does this version or the newer version 2.5 support this feature for non LabView applications?  my code is written using the Visual C++ driver(nicanmsc.lib).
Message 12 of 16
(2,832 Views)
Yes NI-CAN 2.4 or later (2.5.2) supports this feature for C++ 6.0 as well.
DirkW
Message 13 of 16
(2,826 Views)
Hi Ryan
I don't do a lot off CAN stuff so I am not upto date on all  aspects of CAN.
I assume that the list above are CAN error message ID's.
Are these documented somewhere as I seem to have missed readinfg about this before.
I use Vector sometimes but was not aware of error frame ID's before.
Ta
Colin
Message 14 of 16
(2,747 Views)
I was wondering if the current NI-CAN driver 2.6 or version 2.5.2 had any improvements on capturing the error frame.
Russell
Director of Engineering
G Systems, www.gsystems.com
Certified LabVIEW Architect
Certified LabVIEW Embedded Systems Developer
GCentral
Message 15 of 16
(2,431 Views)
oops. I didn't read the second page of the post. I apologize. Disregard my question.
GCentral
Message 16 of 16
(2,429 Views)
