How can I communicate with my PCMCIA-CAN/2 card using Java?
I need to write a Java program to send messages via CAN. The program I used with the Win NT driver of the PCMCIA-CAN/2 card worked. But I have to use Win 2000 now and the new driver nican V 1.6 doesn't work (can't send messages via CAN from my Java program). Thanks in anticipation.
(4,049 Views)
Do you get any error code/message back? Sounds like the Java wrappers that you made for the C dll's need to be recompiled? If the application runs in a weird way using the bus monitor.exe (\NI-CAN) would help.
(4,049 Views)
