03-30-2006 09:35 PM
04-03-2006 12:19 PM
Hi Whycan,
In General it should be possible to use both ports at the same time. See the attached example which uses both ports in a loopback test at the same time.
Did you get any error message you can provide?
DirkW
04-04-2006 03:33 AM
04-04-2006 08:29 AM
Hi WhyCAN,
In this case there is no big difference. You need to configure both ports only ones to read and write on the same port.
attached you can find an example showing how to do so in ANSI C. But it should be similar for C++.
DirkW
