How can i suppress the bus off of a NI CAN card without resetting the device
I want to resume my CAN application from a bus off without setting up all my tasks again.
Is there any solution known for this issue?
(6,176 Views)
if you use frame API, try ncAction -> Reset. You could also try to stop and start the task again.
Let me know if that helps.
Kind regards,
Andreas Stark
LabVIEW Lead @ Rocket Factory Augsburg
(6,174 Views)
