How do I read and write on the same CAN Port
I have a PXI chassis with a NI PXI 8464 CAN card.  I am learning to use this device.  I am trying to send messages back and forth between the two ports on the card.  I have four simple VIs:ReadWas; WriteWas;ReadSteering; and WriteSteering.  I have been starting the read VIs first then starting the write VIs.  When I start the write VIs I get an error from CAN init saying I am trying to change an object that is running.
Is it possible to send and receive on the same port of the CAN card without stopping then reinitializing the card?
 I have attached ReadWas, ReadSteering and WriteSteering to this post.  ReadWas and WriteSteering share a CAN port.
Any help is greatly appreciated,
Phillip
(3,750 Views)
have you looked at this example, (CAN Send & Receieve using NI-CAN Frames) it is in the example code section
http://sine.ni.com/apps/we/niepd_web_display.DISPLAY_EPD4?p_guid=E993D9B56C3D2BABE0340003BA230ECF&p_...
Basically, you are getting the error because the second time you call CANconfig it realizes it is already open. Try consolidating the 2 pieces of code into 1 CAN VI.
(3,741 Views)
