How to check PCMCIA-DNET cable
I'm wanting to check the cable provided with the PCMCIA-DNET card to see if it is functioning properly. What is the procedure for this.
(4,219 Views)
bzielinski,
Probably the best way to check the cable would be to connect a device up and see if you can talk to it (like with a simple who). Are you having problems in your application that might lead you to believe that the cable is bad?
Craig H.
NI Applications Engineering
(4,219 Views)
Simple Who does not work, and I just got the PCMCIA card back from NI. The problem I was having before (Card would not pass self test) is fixed, so I suspect that the cable may not be working properly.
(4,219 Views)
