How to increase the CAN write buffer size
I need to write a 12 CAN messages of size 64 bits in CAN port for every 250 milliseconds. After executing the application crashes, asking to increase the buffer size. How to fix this ?
(6,555 Views)
Could you please put more light on the application you have developed.
(6,511 Views)
You should be able to achieve this by initializing the whole 12 messages in a single task (use channel API)with sampling rate as 4 (4 times\sec). Try with init Start VI and feed the channels of all this messages (Approxly 12*8 channels - Depends on your database).
(6,506 Views)
