How to install CAN-Card
I have problems installing a NI-CAN-Card. Other Cards like NI6527 are working without problems.
What i did is:
Installation of NI-CAN 2.0 then shutdown and installation of the Can-Hardware. After a reboot the card was found as "PCI Simple Communication Controller". I tried 3 different slots always with a complete deinstallation of the Can-SW.
Now i found on ni.com a update for the CAN-Driver. I donloaded the version 2.13 and unzipped the exe-file. But when i run setup.exe i get this error-message after about 50%:
MsiError 1627: 1: 2707 2: SystemFolder1.43DB86AF_A1F6_11D3_94F8_004005586796
Exception code: E06D7363 ()
Fault address: 7C57E592 0001:0000D592 C:\WINNT.W2K\system32\KERNEL32.DLL
Registers:
EAX:00FBFAEC
EBX:00000001
ECX:00000000
EDX:0000000C
ESI:00FBFB7C
EDI:00FBFB0C
CS:EIP:001B7C57E592
SS:ESP:002300FBFAE4 EBP:00FBFB3C
DS:0023 ES:0023 FS:003B GS:0000
Flags:00000206
Stack Trace
Address Frame LogicalAddr Module SymbolName + Offset
7C57E592 00FBFB3C 0001:0000D592 C:\WINNT.W2K\system32\KERNEL32.DLL RaiseException + 85
004C3670 00FBFB7C 0001:000C2670 D:\NI Can 2.13\unpacked\setup.exe
0046F567 00FBFC38 0001:0006E567 D:\NI Can 2.13\unpacked\setup.exe
00446837 00FBFCE0 0001:00045837 D:\NI Can 2.13\unpacked\setup.exe
0046416C 00FBFD84 0001:0006316C D:\NI Can 2.13\unpacked\setup.exe
00464256 00FBFDA8 0001:00063256 D:\NI Can 2.13\unpacked\setup.exe
0046B9B1 00FBFDF0 0001:0006A9B1 D:\NI Can 2.13\unpacked\setup.exe
0046BA6E 00FBFF18 0001:0006AA6E D:\NI Can 2.13\unpacked\setup.exe
004EB695 00FBFF80 0001:000EA695 D:\NI Can 2.13\unpacked\setup.exe
004C93FD 00FBFFB4 0001:000C83FD D:\NI Can 2.13\unpacked\setup.exe
7C57438B 00FBFFEC 0001:0000338B C:\WINNT.W2K\
system32\KERNEL32.DLL TlsSetValue + 240
What am i doing wrong?
- What can i do to revognise the card with version 2.0
- Or, how can i install version 2.13?
Thanks for every hint you have.
DAQ-version is 6.93
(3,812 Views)
Hello Panastra,
do you have a Series 2 NI-CAN card? The new cards are not supported by NI-CAN 2.0, you would need NI-CAN 2.1 or higher.
The problem with the installer error might be a result from a broken or failed download. Does it help, if you download the file again?
Hope this helps.
B2k
(3,812 Views)
Ok, the problem is solved.
I uninstalled broken DAQ 6.93-version, then reinstalled it and then i downloaded the current CAN-version 2.13 and installed it.
Now everything works fine.
Thx for the tip with the too old CAN-version
(3,812 Views)
