How to read broadcast rate from an imported dbc file in MAX
Is there any way in MAX to view the broadcast rate of a message that I imported from a .dbc file?  I would have thought that would be in the properties of the message, but I'm not seeing it.  Hopefully it's something simple I'm missing?
I'm using LabVIEW 8.0...
Thanks....
(7,186 Views)
Broadcast rate is not a property that can be handled in MAX, there just isn't any way to edit or control it. It is implemented in LabVIEW and the CAN drivers, and even though the data is included in the .dbc files, it must be handled in LabVIEW. A good tutorial can be found at https://www.ni.com/en/support/documentation/supplemental/06/the-ni-can-channel-api.html
I hope this helps
(7,177 Views)
Ok - thanks.  NI may want to consider adding the ability to view it though. If you can import and use a dbc file, it'd be nice to be able to view all the information in it....
(7,174 Views)
I will post a product suggestion for you.
(7,172 Views)
