How to read data from server using Can Bus protocol
Hi everyone,
I start by saying that I have a base knowledge of LabView. I own LabView 2011 and a 6 month LabView 2014 trial. I also have the USB-8473 CAN Interface and NI CAN1400 drivers installed on my computer.
Through the interface I will be connected to a server to receive different pieces of information. The protocol used by the server is CAN-Bus protocol, which is a standard that I don’t know so much.
The server awaits CAN-Bus frames, that have a 11-bits identifier. To receive information from the server I need to send it a request like the one in the image attached.
To be precise I should be sending a frame made up of only one 11-bits ID and one value of RTR equal to 1.
So the server is supposed to answer me with a frame containing one 11-bits ID, a RTR value equal to 0, and 8 bytes of application data where I can read all the information I need to know.
I was wondering if you could help me giving me a working example for LabView with whom I can send a 11-bits ID to the server and receive a frame of answer from it. The 8 bytes received should be printed on screen one by one.
The only examples available after the installation of the drivers NI-CAN show me how to read/write not  simultaneously data from can bus  . Instead, I need to read data from can bus  , but to do this I have to send the server a frame of request.
Thank you very much for your attention. If could give me a working example I could start developing all the implementation I need.
(7,165 Views)
There is a shipped example called Transmit Receive same Port.  THis allows you to constantly be reading the CAN bus, but then when you click Write can send a frame with the ID and payload you want.  In this way you can send your data, and see the response in the table as it is read.
(7,148 Views)
Thank you very much for your help. I've found the example and it's been really helpful. Just what I was looking for!
(7,136 Views)
