How to search the words in text file using CAPL
I have text file say test.txt and I have to search some 10 words from that text file. Could someone please help how can we search words from that text file using CAPL
(8,919 Views)
Check out fileGetString. Below is what is an example code in the CAPL help menu.
variables
msTimer writeTimer;
long glbPeriod = 250;
dword glbHandle = 0;
long glbValue;
on Start
char buffer[64];
long ret;
// Opens the file in ASCII mode for read access.
// To determine the absolute path, the search procedure will be used.
// The file must be located in the directory of the databases or the
// configuration directory.
glbHandle = OpenFileRead ("Data.Txt",0);
if ( glbHandle!=0 )
// got to end of file ...
while ( fileGetString(buffer,elcount(buffer),glbHandle)!=0 ) {};
// Get the last parameters
// (saved on disk after the end the last measurement)
glbValue = atol (buffer);
write ("Last value %d.",glbValue);
fileClose (glbHandle);
else
write ("File 'Data.Txt' was not opened for read access.");
// Open the file in ASCII mode for write access.
// The write path was not set using the function setWritePath(), so
// the configuration directory will be used instead. This is the
// default behavior.
glbHandle = OpenFileWrite ("Data.Txt",2);
if ( glbHandle!=0 )
setTimer (writeTimer,glbPeriod);
else
write ("File 'Data.Txt' was not opened for write access.");
on timer writeTimer
long randomValue;
char buffer [64];
if ( glbHandle!=0 )
randomValue = random (32767);
snprintf (buffer,elcount(buffer)," %d \n",randomValue);
filePutString (buffer, elcount(buffer),glbHandle);
else
write ("Error, invalid file handle.");
on StopMeasurement
(8,762 Views)
I tried the example given by CAPL and it works. But, in this instance, numbers are written line by line. If i write in the same line 5 numbers, how do yo do to get the 3rd number ?
Sincerely,
Karbure
(7,284 Views)
