How to send Extended ID to a CAN node
I have a  DUT to transmitt the CAN messages for every 400ms with Standard and Extended ID(At a time either Std or Ext ID CAN message is transmitted). I have used the Labview sample code( transmit receive same port.vi) for receiving and transmitting the messages. The code is working for Standard CAN ID. But the same is not working for the extended CAN ID. The sample code is keepon receiving the CAN message with same Extended ID for every ms even though the DUT is transmitting the same for every 400ms.
(6,301 Views)
I'm not shure to understand your problem to 100% but you might be interested in this discussion about the 30th bit for the extended ID.
(6,299 Views)
