How to trigger frame transmit when specific frame id arrived?
Hy,
I'm using X-NET, with C++, Windows7 OS.
Can I triggered a transmit of frame when a specific id arrived from the network, without polling data with nxReadFrame?
(By the way, this is one more thing that old PCI-CAN can do with his Notification feature... )
Thanks for advance,
Aviad
(6,255 Views)
Hi Aviad,
What hardware are you using?  Also, if you have a chance, I would recommend reading through this DeveloperZone Article. It describes the differences between XNET and CAN. I don't believe there is a similar 'notification' feature in XNET but I will continue to look into this.
Best Regards,
Allison M.
ni.com/support
(6,237 Views)
I'm using X-NET, NI PCI-8512.
I'm already asked about the 'notification' at the forum, answered that there is no same feature at GENET. I believe that u will work about it at future, It's very necessary....
aviad
(6,226 Views)
