I don't arrive to receive CAN data with a visual basic software!
I recuperate a Visual Basic code (obj2obj) in your forum (How can I program the NICAN-card with Visual Basic 01-17-2003) in order to receive CAN data. However, I met some problems because the connection doesn't seem very easy. The following error appears: "ERROR; ncWaitForState: Unknown status. 1074388991 ".
With others applications, it is possible to connect two computers and to receive CAN data with the twice computer from the first computer. This even operation is not possible with the Visual Basic code.
I would like to know how it is possible and why this code doesn't succed.
Bests regards.
Vince22
(3,581 Views)
This error (Hex 0xBFF62001) means the timeout of a wait or notification function expired before any desired state occurred.
Solutions: Increase value of Timeout parameter; Verify your cable connections and operation of remote devices
Are you sure of the name of each CAN port (you can verify it in MAX) ?
regards,
Marc L.
NIF
(3,545 Views)
