I have configuration file for VECTOR CAN and want to port to NI CAN card
I have CAN analyzer with for Vecror CAN card. Now I want to use the NI CAN analyzer for the same application. What are all teh files that can be compatible with NI CAN card. I have
.dbc
.asc
.ccp files with me, please suggest on having the same with NI CAN card.
(6,900 Views)
laxmi,
The NI-CAN Channel API (available on PCI, PXI, PCMCIA interfaces), can directly import and allow you read/write data with channels defined in .DBC files. .DBC is somewhat of a de-facto standard in the industry. You can play around with this functionality without the CAN interface, simply download and install the NI-CAN driver software (https://www.ni.com/en/support/downloads/drivers/download.ni-can.html) and you can import the DBC files into the Data Neighborhood branch in Measurement and Automation Explorer.
.CCP is used with CAN Calibration Protocol and supported in our ECU Measurement and Automation toolkit.  This is a separate toolkit available for use with NI CAN interfaces (including USB).
https://www.ni.com/en-us/shop/product/ecu-measurement-and-calibration-toolkit.html
You can download and evaluate it for free here:
https://www.ni.com/en/support/downloads/software-products/download.ecu-measurement-and-calibration-t...
Hope this helps!
--Paul Mandeltort
Automotive and Industrial Communications Product Marketing
(6,843 Views)
