IEEE 1394 Camera Not Visible in MAX
Problem Description :
I'm using the following hardware:
1. Texas Instrument OHCI Compliant IEEE 1394 Card ( Ratoc PCIFU2)
2. Basler 601f Camera ( NI certified)
(DCAM v.1.20 compliant)
Sofware :
1. LabView 7.0
2. Max 3.0
3. NI IMAQ for IEEE -1394 Ver 1.5
4. Vision Development MOdule 7.0
I am able to use the camera via Vision Assitant (7.0), but unable to see
the
camera listed in MAX. I have tried all the steps listed in FAQs.The driver
for
the camera is 1394imaq (i.e. all this has been checked).
I can run the 1394-Imaq vis & acquire images as well, but like i said no
camera listed in max ....
NI Software : LabVIEW version 7.0
NI Hardware : Other device
Driver Version :
OS : Windows 2000
Customer Info
rmation :
MK
krishnamukund@hotmail.com
(3,981 Views)
It looks like the MAX provider for NI-IMAQ 1394 may have been corrupted. This can usually be fixed by running a repair on the installer. You can do this by running the installer from Add/Remove Programs.
Hope this helps!
Best Regards,
Yusuf C.
Applications Engineering
(3,982 Views)
