09-27-2011 03:00 AM
I faced the problem for communicating Bosch ECU using NI USB CAN 8473s.
I am using KWP 2000 protocol with ISO TP standard.
While establishing communication, the CAN led bliks for a while and goes off.
Is that mean, my send message is working & receive is not?
After running vis, it gives error 8210 pop up.
Please suggest solution.
10-04-2011 07:27 AM
Error 8210 (I assume -8210?) indicates a negative response message from the ECU with a 0xD2 error code. This is not a standard error being returned... so you should probably consult your ECU manufacturer. I assume it's a manufacturer specific error code.
Christian
