Install of PCMCIA CAN Series 2 Card
When I boot up my computer with my NI PCMCIA-CAN/2 Series 2 card, it locks up in mid-boot.  If I try to put the card in when windows (XP) is running, it freezes.  I had this problem at first, and then it disappeared for a short time, but is back again.   I essentially had to re-boot my computer several times before it recognized the card, but this trick has stoped working.  I have installed the latest NI CAN software (verson 2.3) and still am having the problem.  The card is new.  I recieved it in march, but only just pulled it out about a month ago, and have only had a few days since then to try and work with it.  What could I try to fix this?
(3,477 Views)
Hi James,
That sounds like as if you got a bad card. Your card is still under warranty. Please contact your local National Instruments branch office to get the board checked/repaired and give them the same description of the problem.
-B2k
(3,471 Views)
