Is it possible to run two separate networks with NI-CAN PCI/2?
I want to get two independent CAN networks running with two sepate sets of vis, how is this done with the NI-CAN PCI/2?
(3,785 Views)
Yes it's possible. The config util "C:\Program Files\National Instruments\NI-CAN\CANConfig.exe" associates each port to a CAN name and then you can reference/use them in 2 separate CAN networks. You can modify examples in LabVIEW, C:\Program Files\National Instruments\LabVIEW 6.1\examples\nican or make calls to the NI-CAN dll.
(3,785 Views)
